FrankWest
Started dropping the oil pan, just loosened bolts. I purchased this special screw attachment to keep the oil pump from falling out after dropping the pan. Where does that screw in. Searching under distributer side of engine near above drain hole in pan below distributer. I see one screw??
does that get removed and this crew tool inserted there??
There are not many diagrams about this. I even have The model A mechanics handbook and there he cautions do not screw in the pump with side screw?
Maybe things have change on model B engine. Any help will be greatly appreciated!
Thanks
Thanks
