K r wilson engine stand
Gary in La.
LAFAYETTE
LA.
Price
500.00
Here is an original KRW Engine stand with tool tray and one special adapter (not sure of usage) which could be used as a base for a flathead mount plate. The only issue is the base of the stand has had a small section cut out of it at the bottom of the vertical support for some unknown reason in its past.Do not think the strength is greatly affected as the construction overall is very heavy duty. Can always weld in another piece. $500.00 PICK UP ONLY. NO SHIPPING UNLESS BUYER MAKES THE ARRANGEMENTS. If interested send me a PM. Located just off I-10 at Lafayette, La.
