K r wilson engine stand
Gary in La.
Lafayette
La.
Price
$800.00
Here is an original KRW Engine stand with tool tray and one special adapter (not sure of usage) which could be used as a base for a flathead mount plate. The only issue is the base of the stand has had a small section cut out of it at the bottom of the vertical support for some unknown reason in it's past. Do not think the strength is greatly affected as the construction is very heavy duty. Can always weld in a new section. $800.00 PICK UP ONLY. NO SHIPPING. If interested send me a PM. PICK IT UP ON THE WAY HOME FROM THE PATE SWAP MEET. LOCATED ALONGSIDE I-10. Lafayette, La.
