Hitman,I understood what you are after.I saw somebody mentioned using a pipe vise to work on the rear ean,and I went off on a tangent and responded to that.Years ago I had somebody stop by looking for things like you want to make up a display.I sold him a KRW engine stand for the A.It was a rectangular frame set on cast legs,and the whole frame pivoted around to get at both the top and bottom of the engine.I believe it bolted to the pan rails.I used it to work on truck rear end chucks.It took up a lot of space.I may still have a KRW valve grinder with a setup on it to grind the valve stems.I actually had two of those,one went to somebody on here a few years ago.
