Tom Wesenberg
Yesterday when that worn out water pump chewed up the radiator, the truck had been setting in the parking lot for at least 1/2 hour with both sides of the hood up when I drove in. I could still see the light whifts of smoke and rays of heat rising from the engine. The upper rear half of the engine was burned dry and completely free of any paint, grease, oil or dirt. It has the same look as a block that had just been red hot and pulled from a fire. I felt the radiator and it was cold because there was no coolant to circulate. After a bit a guy came over and shot the engine with his heat gun. The engine was still 354*. The owner said the truck was making a racket and had to get towed for the last couple blocks into the parking lot. When the flatbed arrived the owner started the truck and drove it on. It actually sounded OK and didn't knock or smoke.
I would have guessed this engine was doomed.
