PotvinV8 , yeah those brakes are sweet alright , but I'm not ready to sell the farm yet to get one , about all I'm lacking at this point to have everything to finish the job is the proper Master Cylinder , it will be manual braking , so I'm told it must be a manual MC , with a small bore , dual port , any suggestions ?
You can purchase the reproduction "Lincoln" backing plates that are made to fit the Model A front spindles. Then you use the 40-48 Ford front hubs and drums. Everything will fit.
Just a suggestion,
Chris W.
You actually want a large bore master. I think the '40 master was 1 1/16" bore if memory serves me right. Standard swap for a dual master is the '67 Ford Mustang for a drum/drum setup, that's what I used. If you get lucky, it will have the residual pressure valves built into the master, so one less thing to mess with. You can stick a paper click in the port and if it feels spongey, that's the valve.
Have you figured out how you're going to actuate the master? Stock Model A pedal is set up to pull as opposed to push, which can make things interesting.
Good luck and enjoy your A!
What is the bore on the 67 Mustang drum/drum master cylinder? I need a 1 1/16 bore or the pedal travel is too much and the brakes go neatly to the floor. Asking at the parts store is a waste of time.
I'm getting tired of explaining all this stuff! 39-48 brakes fit the A spindles with a kit, we used to just use a Model A piston ring and a hard-seat for A valves to space the bearings. Yes, the backers need some slight elongation, doesn't weaken them. Afraid of cutting a slight slot in the rear backers? Gimmee a break! Are hydraulics better than mechanicals??? If not we'd be driving our Toyota's around with mechanicals, and spending a lot of time and/or money trying to keep them working right! Afraid of rust? Use silicon fluid. How many late-model cars have break failures? Not many, almost zero. Opinion from a very experienced 83 year old phart.
p.s., don't know about F-150 brakes.
Hydraulics are better than mechanical brakes because they are self equalizing.
On our mandatory annual safety test they match brake performance on modern cars.
