... With the original drums the outer rim of the wheel hub rests squarely against the side of the drum, however with the type of new 1940-48 drums I'm thinking of buying there is a gap.
This does not seem right. I will drive the car in dirt track races and want full support of the hub, or is this not necessary? Does anyone know? Would original 1940-48 drums work better, or is it the same issues also with those?
Marcus,
There are two separate issues involved here.
I believe your post refers to the extreme
outer circumference of the wire wheel hub contacting the brake drum (issue 1) and
not the wheel/drum contact points next to the wheel stud (issue 2).
Issue 1. From the factory, the 32 - 35 wire wheels contacted the drum at the outer circumference of the wheel hub. There will be a gap at this point when using the wire wheel with some (maybe all?) of the
repro 40-41 drums. I measured this gap at about 0.070" with the Lincoln repro drums. Some OEM drums seem to eliminate the gap (based on my limited sample).
I sympathize with your desire to have "full support of the hub" especially given your intended use. However, there have been 100s of cars with this wheel/drum gap running around for decades seemingly without problems. Of course, most are in much less demanding service that you intend for yours.
Issue 2. (This issue is not obvious when you just plop the wheel on the 40 - 41 drum.) There is a need to add a spacer ring to the wheel so that the wheel will contact the
flat mounting surface of the later drum (either repro or original). (The OEM 32 - 35 hub/drum contact points were not flat and the wheel contact pads near the stud reflect this.) The responses you've received mostly address this issue.
Hope this helps.
John
