Ball and Chain
I'm converting my 35 to juice brakes via 39 master and 40 drums. I re ran the hard lines the same as what was on the 40 rear end when I got it. Ran hard line from the wheel cylinders down both radius rods (40) then jumped over to one side to hit the juction, then went to a flex line (one side into the junction and the other side is mounted to a tab on the torque tube.
My question is the flex line seems pretty rigid to the torque tube, so it is just hardline from there that tab to the master. Is that the only flex line i need between the rear wheels and the master? Every pic or breakdown I find I can't see if its flex or hard line after that and it just seems too rigid or maybe it's fine.
Thanks Kevin
Thanks Kevin
