Frank Miller
Johnsons been leaving spots for years.
Just curious,
What did the original Johnson holding tool (singular) look like?
John
Johnson lifters are much heavier than stock (unadjustable) FOMOCO lifters. Lighter is better. There is a significant difference in weight among the various Johnson-style lifters on the market. Shop around. One way to spend a quiet evening with a postal scale is to weigh each lifter and file the ones that are heavy. It might not make any difference in the 0-60 time, but it seems like the right thing to do.
I used to run a Napa machine shop the last 10 yr's of my work career. I've been (retarded) for 15yr's but we used the have those lifter with the thicker heads in the Napa parts book. WaltAnswer to the original question is no. You cannot use the type of Johnson lifter shown with a reground cam. It will be too short and because the screw has to be let out so far to adjust, it will not hold its adjustment. The correct Johnson lifters have a higher screw head (nut) and were made for reground cams. That version is no longer in production. You can tell the difference easily, the part where a wrench goes to adjust is much thicker.
Rather than file the top, could you just drill holes in the sides of the lifter to lighten it? I know it's hardened steel, but a carbide drill might work or perhaps water jet cutting.That would be a lot of filing.
John
