John Deer Corn grease --- ugh
30-9
So I buy the John Deer corn grease to use in my steering box. I follow the instructions, but low and behold the canister doesn't fit into the grease gun.
Am I crazy or shouldn't the canister (which has openings on both sides( fit in the gun?:confused:
When I was farming the JD corn head grease I bought came in a can and you poured it into the receptacle on the combine.
It's not corn grease its corn head grease. Whatever a corn head is. Some sort of agricultural implement. I'm not a farmer.
It was/is used the the gear boxes on corn head equipment. It is a low speed gear box similar to the gearing in a steering box.
In NZ had same problem. The Corn Head Grease cartridge would not fit into my grease gun. I purchased a grease gun from John Deere when I got the grease.
I also got it to go into my steering box. And also for drive shaft universal clam shell.
No complaints about having to get another grease gun as now this one is just for the Corn Head Grease and other one with EP Grease for king pins, tie rods etc.
Phil NZ.
I've only ever seen one size of grease cartridges sold here and they all fit any of the grease guns I have. You must have a non standard grease gun if there is such a thing. You always put the end without the metal ring into the gun first down against the plunger of the gun. I don't think it is possible to put the cartridge in backwards.
What Ralph says X2 ..........F F:)
I've been using this stuff for years and each cartridge has fit perfectly in a "standard" grease gun
Ditto here, the cartridge is a standard size and fit my grease gun fine.
You may have tried to put the pop-top end in the gun first. The reinforcing ring at this end will NOT go into the gun. The end that has a plastic or cardboard cap on it, once removed, is the end to insert in the gun.
Phil NZ.
Good to hear one has same issue.. I bought this gun at Harbor Fright so that may be the problem. I bought a cheap gun from them thinking, just filling steering box I didnt need a good gun...ho yum... you get what you pay for.
I'll go to John Deer and buy a gun w next purchase.
I have two grease guns, one I've had for decades and another I bought a couple of years ago from Harbor Freight specifically to keep the JD corn head grease in.
My Harbor Freight gun took the JD cartridge with no problem. Are you sure you tried to put the capped end and not the pop-top end, into the gun first?
Yes, I followed the directions. The tube is too large to slide in.
