in the midst of a 37 ford pickup rebuild . motor is 21 stud flathead with Mallory ignition, 4 in crank, 20 over bore , cyclone heads and thickstun intake dual carb motor rest of pick up is stock except converted to 12 v neg grd.
question is what jetting would I use and how do I determine the correct size? the carbs on had 65 size jets. On adual carb would you have both carbs the same size? They appear to be synced to open same time with current setup
