1931 flamingo
I do: glug-glug-glug-glug whenever I get gas. Not going to hurt a thing.
Paul in CT
Paul in CT
I once saw some "JERKY RUNNERS", while running, they were talkin' to one another, on their CELL PHONES!
Bill Babble
Glad it worked out for you Fred.This tells me that you need to start looking for more parades during the year.
And for what it is worth, i always add about 4 oz of MMO every time i fill up on both of my A's. Mark.
Mark, the MMO idea sounds good. Will have to do. But I think the parades may go. Hard on the old rig, clutch etc. So think I will watch parades instead of being in them!
Well back in Aug of 2018, I started this post about my jerky 29 coupe. Guess what, here it is Sept 2019 and I have the same problem. Same situation, ran it is 4th of July parade, let it set until now (sept) and the same problem started again. The problem was that when I would start to go, press on the gas it would jerk and backfire in the carb.
So I did some thinking about the situation as to what it was doing--- would "miss" when pressing on the gas starting out from a stop. Well so many people recommended Marvel Mystery Oil so I got carried away. A few days ago I took the plugs out, dumped in a bunch of MMO in each cylinder, and let it set for a few days. Today I got in it, started it up(and it did start) and I had a concern that the neighbors would call the fire department. So I backed outside and let it run for awhile blowing smoke all over the neighborhood. Then I got in it and drove it around the block a few times in 1st and 2nd. At first it still had the problem. Then after a few rounds it all cleared up-smoke and the jerk (not me).
After parking it after a few miles, I turned it off and let it set for while. They I tried to start it. I had spark up, gas lever up and just a touch of the starter, it was up and running! Wow! This start was better that it had done for years. I also pulled one of the spark plugs and looked at it. Before the MMO, when I took them out they were covered with black junk. This time the electro look nice and brown and no black stuff.
Anyway to sum up all these comments- it does look like I had a stuck valve. Putting the MMO in the cylinders and running it after that did clear up the problem of a jerky start where it would jerk and backfire in the carb.
Hope this helps someone.
Thanks, good information.The two most common problems that can happen after a car sets for a time is fuel deterioration and sticking valves.
Fuel doesn't last very long unless it is a higher quality formula like 93 octane premium. Avgas last a lot longer but it's overkill on a model A and it's not legal to run it in cars. Draining the fuel is a PITA but sometimes it's the only way to insure a clean fuel system.
MMO and running the engine regularly are the best way to prevent sticking valves. I wouldn't use any more MMO than is necessary. This isn't a 2-stroke engine and they generally get enough blow by to keep the piston rings lubed up. They don't run well on oil and solvent alone. It doesn't take all that much MMO to do the intended job.
We run the aircraft engines every 2-weeks if they are in flyable storage. This is considered the minimum interval for safe flight. Even 2 months is too long.
