31 Model A
What a good reliable jack to have along on a drive? Don't need original one of the time period, just a good jack that is best to use for changing tires on an A?
Thanks
Ed
Thanks
Thanks
Ed
Thanks
1 ton will easily lift any of the 4 wheels, but it's the quality of the jack that matters. For instance, the scissor jack comes in a narrow flimsy build, or a wider better quality build. I'd only use the wider better built one. A Model T screw jack would probably work OK, but I like the larger base and heavier build of the AA screw jack.
Tom,1 ton will easily lift any of the 4 wheels, but it's the quality of the jack that matters. For instance, the scissor jack comes in a narrow flimsy build, or a wider better quality build. I'd only use the wider better built one. A Model T screw jack would probably work OK, but I like the larger base and heavier build of the AA screw jack.
