aaron griffey
A better ground isn't always the answer.With !2 volt cables on a 6 volt system you are still gonna turn the engine over slow.
So many cables have been replced with the too small 12 volt type. Not good.
You gotta have a size #1 or larger negative cable, starter cable and ground or the 6 volt battery will never turn it as fast as it should.
I have converted many 8 and 12 volt systems back to 6 volt with the amazment of the owner after putting in size 1 or 0 cables.. I'm doing a model A this friday. It is 8 volts and I'm betting the cables are 12 volt because he wants me to put in an alternator.
If you want a modern radio, or any radio, I suggest you go to 12 volts. Otherwise... na!
