like ol ron is thinking, valve hitting head, no telling how many times a stock head has been milled, no matter what your going to have to pull the head and find the problem, look for marks on head above valves, set the head on with just a couple of head bolts loose just to hold the head in place with out a head gasket, turn engine over by hand, if head rises ,not enough clearance between head and valves, if that is the problem get new heads or have yours fly cut above the valves
