I'm looking for a timing tag for an ISKY LDB on a 59a style cam Has approximately .290 lift
I believe that is an Ardun cam and it stands for "Long Duration Bigalow". Looks like it is a steel core cam - maybe created from a 32 billet. Not much lift . . .
Does an Ardun conversion have push rods and rocker arms ? If so, that would explain the low cam lift since the rockers were probably around a 1.5:1 ratio.
Sal
Original Ardun rocker arm ratio is only 1.2:1.
Using that ratio, it would give you .348" of lift.
To put that in perspective, a stock Ford cam has a lift of .307, while the Isky MAX-1 has a .364 lift. This may not be a direct comparison, because we don't know how the lifts on the respective cams were measured.
I think some of those issues were address in the Ardun thread, a short time back.I know nothing about how to set up Arduns, but after watching the IronTrap video and hearing what Ronnie Roadster said, there can be clearance issues with the push rods when using a "performance" cam on these units.
Curious at what lift does the clearance issue come into play.
