Isky 404-a value?
BEACHBUZZARD
New member
Have a new isky cam (49-53) 404-a...had planned to use it but research has determined it is too radical for my needs...works with nitro or blower...what is a fair value for this item?...thanks...beachbuzzard
Depends on weather you have the radius lifters with it? Pretty us-less with out them. I think Pete has them
If I remember correctly, you also need a special Jig to drill the lifter bores to keep the lifters in place.
I'm sure you can get all that stuff from Pete.
Yup.
A used cam without lifters is worth about $50.
A genuine NOS Isky complete with seal and lifters would probably bring about $500.
These do work good on the street if you don't abuse them with rpm.
