Phred
1936 Ford 4dr
Is a 24 stud engine original to the 1936 model year?
Were aluminum heads also cast 59AB?
I want to connect the existing accessory hot water heater that is mounted to the interior firewall. I looks like the ports next to the cylinder head water outlet might be a great place to capture hot water to send INTO the heater core, or is there a better place to capture the hot water for the heater?
Where is a good spot to RETURN the heater water back into the cooling system?
Thanks in advance
Thanks in advance
