Where the heck in the VIN number on the frame?
I was going to go by this posting to find it.
https://www.fordbarn.com/forum/showthread.php?t=251577&highlight=vin+location
I noticed you just wanted some chassis parts.
Just a heads up, but the Mercury cars had different front spindles, front wheel bearings and races and all the brake drums from the Ford. The rear axle of the Merc has different axle shafts (with hubs having the larger bolt circle).
Basically, you could take all the Merc suspension parts off collectively and swap them on a Ford frame, but you can't mix and match Ford and Merc components.
I'm not sure about the upper and lower control arms. Merc may have had larger pivot pins and bushings on the lower arms. As I recall from long ago, it seems like Merc had a lot of suspension components that were heavier than the Fords.
