Neil Mylar LakewoodCA Well-known member Jan 30, 2014 #1 Can anyone tell me if this is an original popout? It does say 'electrolock' on the back, but I do not see a number on the bezel. Thank you Attachments P1180026.JPG 158.4 KB · Views: 202 P1180025.JPG 164.5 KB · Views: 213 P1180031.JPG 161.3 KB · Views: 200 P1180029.JPG 160.7 KB · Views: 170
700rpm Well-known member Jan 30, 2014 #3 No. But I'll give you $5 for it, just to get it out of your way.
Neil Mylar LakewoodCA Well-known member Jan 30, 2014 #6 Why is there no visible number? Also I saw another popout that had just an enclosed letter <B> on the back cover. Could it be an original?
D Drive Shaft Dave Well-known member Jan 31, 2014 #7 That one is original also, < B > Briggs and Stratton Co.
out plowing Member Mar 3, 2016 #8 Where is the key code on your popout? Mine looks similar and I can not find the A??? Number so as to get a new key made.
Tom Wesenberg Well-known member Mar 3, 2016 #9 Follow this link for pictures of the key number locations. http://www.fordbarn.com/forum/showthread.php?t=122329&highlight=popout+number
Ron in Quincy Well-known member Mar 3, 2016 #10 The keyway in the 3rd photo just does not look right with the large opening at the top ? The later pop outs have a small hole for releasing the cylinder which would have a Key # on it. Ron
