Is there somewhere to get a shock adjusting pin/pack nut?
MartyAndrew
Hi all. I've tried Snyders and Brattons and niether lists a shock adjusting pin/pack nut set. Where else can I get one? I have one that I'm getting concerned I won't get out. Last effort is trying MOT's electrolysis setup to loosen any rust. Doing that now...
I thought that I've seen them in one of the catalogs. If they're not in Snyder's or Bratton''s, then it probably was Mac's.
I am unsure of where you could get packing nuts other than the shock restorers in the above sticky. I have a set of very early production slotted packing nuts that are extremely hard to find. This is the only 'loose' set of nuts I have ever run across. Maybe buy a repop adjuster and pull it appart for the packing nut or use as stated above
Thanks Patrick L. You are right, I had the name wrong. Don't know how I missed it in Bratton's. I'd swear I had looked all through the "Shock" category. Thanks again.
If anyone knows of a place to buy one though, I'd still appreciate that. All mine came loose fine except one and Bratton's is a set of 4.
Marty
