The STOCK width on a Model A rod is 1.625, -.007 thousandths, or a total of 1.619 wide.Unless somebody opened them up some.
One point here, everything can seam out of specs., when the Rod is out of Alignment.
And you should go no further until they are checked for twist, bend, and off set.
, because if you haven't, they can be bad enough, they won't fit just because of that. I will guarantee the people that rebabbitted them didn't.
When that is done right, then you can check the fit.
Shaft clearance should be .001-60 at the lowest, and .002 thousandths at the highest.
With Spec's, they should have , .005 to.007 side play.
All hole sizes should be checked with a inside Mic, or sometimes called a Post Mic. I will show a picture, if I can find one.
With a post Mic, you can measure right to the 1/10 of a thousandths every time, after time.
Set the Post Mic, and then read the out side with a normal Mic.
The worst, uncertain inside Mics are snap Gauges, they will not read 1/10's, as they are all over the place, in different readings every time.
Anybody, when you put on rod caps, make sure the cap has its small tapered hole facing the correct direction. The dipper points to the taper hole, closest to the part line, or away from the tapered hole Further from the part line.
Herm.
