Nice wright up Jack, on the flathead engine. May I add a couple of things? The 36 engine with the inserts designation was LB, but not all 36 insert engine got the LB mark. The mains on the LB engine are 2.400 (round figure) the 37 and early 38 21 stud used the same crank as the 36 LB. The late 38 24 stud and later engines went to the 2.500 mains. All rod journals from 32 - 41 or 2 had 2in. rod journals. The 59A and later engine have 2/139 rod journals. Walt
