beast_3
I've been trying to get my '30 Tudor back on the road after a 2 yr. hiatus & I think I have a bad coil. I'm not getting any spark between the points or from the coil.
I've tested the coil (an old oil filled, repo script coil) with my multi-meter & on the 20 ohm scale I get these readings:
between the + & - terminals scale reads a 0 ohm short
between + or - to center reads 7.9-8 ohms
between + or - to case shows open circuit.
One of my manuals says the short between + & - terminals indicates a bad coil.
Also coil gets hot after leaving ignition switch on while trouble shooting.
I've check & adjusted all the other parts of the ignition & it all checks out OK.
Think my coil is bad or have another problem?
Thanks!
Bob
Thanks!
Bob
