rcrra
Completing a total rebuild on 30 A coupe. All new wiring and conversion to
12 volt with a one-wire alternator. Just added gas and tried to start for the
first time since tear-down. Wouldn't hit a lick. Found the fuse blown at the
starter. Replaced fuse and after turning on the disconnect switch( on the
grounded side) the fuse was blown again. After going over the wiring it seems
to go back to the alternator. This is a new alternator purchased from Mac's if
I remember correctly. Looking at the back of the alternator with it installed on
the top right is the main connect terminal for the battery, horn and lights. On
the left is two terminals with a metal connection between to two of them. Is
this correct or should the metal connector be removed. I may be totally wrong
and the problem be something simple somewhere else in the wiring, but thought
you guys might have some suggestion. Sure would appreciate your thoughts
as I am sort of floundering around now.
