Is fuel bubbling normal
I have a 31 Tudor. I notice that the fuel in the little plastic fuel filter I have on it seems to bubble as if boiling when I shut the engine off after driving. The carb is pretty warm but does not seem excessively so. Is this normal or does it indicate a problem?
I would say that it is probably boiling. I can't really think of any other reason why it would be. Do you use any additives in your fuel?
Rusty if your gas tank doesn't have excessive rust/debris and you have a pencil filter in you don't need the plastic filter.
If the filter is a long way from the carb, I can't see how it's boiling. Even if it's close, I would guess it's simply air bubbles as the fuel drains a bit down to the carb as it's shut off. Check its temp with your hand or a cheap infrared temp indicator from Harbor Freight. They're super handy. I just googled boiling temp of gasoline and it's 203 degrees F.
I have clear fuel lines on a '53 Ford flathead and I see a surprising amount of bubbles. If you don't have symptoms of fuel starvation (sputtering and missing at high speed), I'd say you're fine. Good luck
IMO, the sediment bowl that is already in the system is enough to deal with what you'll experience with a clean and sealed tank. Adding an inline filter will just impede fuel flow in a gravity fed system.
If you are getting excessive heat, yes gas will boil at somewhere around 200+ degrees F, depends on the blend. If the timing is incorrect, then there will be excessive heat. If all is running fine, just some boiling in the line at shutoff, it won't hurt anything. If its really a hot day 200 degree engine bay in ok.
Plastic fuel filter. Sounds like a fire hazard to me. Should be a steel fuel line. No rubber no plastic.
Plastic filter is far from the manifolds but I'm probably going to get rid of it as I'm sure it is a weak link in the system.
Thanks to all who replied. weather has turned bad here so I won't be taking it out for a while but I did buy the infrared thermometer and that should tell the tale if the engine is over heating. This car is an ongoing project and I'm glad you guys are here to ask for help.
