Irregular Flash with Turn Signals
Jewels
I just recently completed the installation of a Signal Stat 900 Series Turn Signal Kit from Snyders on my 6 volt positive ground Coupe. Everything works great at idle; however, when traveling down the road and using the turn signals, it is a different story. They flash so quickly that they almost appear to be constant. I followed the instructions and scraped the paint from the steering column to provide the ground.
After reading other threads about turn signal issues, my guess is that it is the 3 prong flasher unit. If you have been down this road, please share what flasher works?
