After installing a rebuilt engine everything worked fine except for this odd irregular clicking sound when driving. At first i thought it was something to do with the running gear, oiled the sqeaky front spring, greased everything still the clicking noise. Sometimes I could drive arond, no clicking, didn't matter if we where driving fast or slow. Once clicking started,turned off the engine and coasted sound disappeared!! OK sound from the engine. Took the alternator and water pump apart, all OK. Removed the starter, bingo the small return spring against the starter gear GONE. The small gear had been bouncing off the flywheel ring and the stop on the bendix!!!!
Oredered a new bendix starter gear. hope this works!!
