Internal electric fuel pump with float sender
Scott
AFAIK all the aftermarket (in-tank) pumps are all 12 volt and high pressure- 45# and more.
I have been told, but have not researched, that up to 1978 some Toyotas had in tank LOW pressure pumps that might be useful in an old carburetored Ford. These would also be 12 volts.
I've never heard of a in tank pump with a guage float, but I live under a rock a lot of the time.
Jim
I believe that early Honda accords had a lo pressure in tank pump. don't know about the gague float
Ford mustang svo 4 cyl 1984 had a low pressure fuel pump as the engine had a carb. If my memory cells are correct. I have one in my 34 5w that I modified to mount in a repro 34 tank. Getting all the parts to fit into the hole of the tank is the hard part if you added a sending unit onto it.
