El caminnow
I have a 29 with a diamond block, runs good however overheats once in a while. Ill stop and idle, look under hood to check things out and then she settles down. I have a motometer to watch temp. it will run normal for 10 mi then suddenly shoot up. The other day i had to shut it down after boilover. Any way i removed pump, seems fine, impeller tight on shaft, very little end play and block and head are very clean inside, possible clogged radiator? Any thoughts anyone? THANKS, Sam
