Interior trim question
mkmskm
Attached is a photo of the piece at the back upper corner from a '29 Tudor where the headliner tacks into. What is the material supposed to be inside the track where the tacks go in? Its not wood - cork? Its dead whatever it is and needs to be replaced.
When I restored a '29 Tudor, I cut strips of thin aircraft plywood on a 45 degree bias and slid them into the holders. I appeared that the originals were some sort of fiber board. Gar Williams
Lebaron bonney sells a wood strip that goes in there with a little fitting. Give them a call if you dont have their catalog.
Thanks guys. There has been some water up in there, but this stuff was so decayed you couldn't tell what it has been originally.
