Interior Panels
GAR64
Re-installing my rear side interior panels in my 56 (2 door). Doesn't seem to be holes in the body for the screws in the panels. Are there some kind of clips to screw into?? Also..confused about the panel that goes between the rear seat and the trunk. Does it install on the trunk side or interior side??? I guess this stuff should be simple but I am finding these details to be tough. We will now see how I do with the new carpet!
The trunk panel installs on the trunk side. Should find several tabs on the metal panels that go thru the panel board and bend over to retain it. Not sure on the interior panels, mine is a 55 Crown. It only has a couple of screw holes, one at bottom by door opening, and one at the rear below window. Mine has the arm rests, not sure if 2 door does or not. Is this a 2 door hardtop or sedan?
Thanks Crownvic55. I installed it on the trunk side but then saw it in pics on the inside. My car is a 2 dr hardtop.
The cardboard trunk panel installs from inside behind the seat backrest. Once you remove the seat, it is easy to see how it fits in there.
