No, I haven’t but could you help me with mine?
1956 appears the guys who wired the car did not bring down two wires from the headliner lamp. Never did work on a headliner. Possible to drop the headliner and fish wire down A pillar and put the headliner back? How difficult is this? Thnx
I don't think you would have to drop the headliner.....remove the metal trim between the doors, (do you have a 4door??) and snake it up over the headliner to the light. Is the light in place or did they not put it back?? You could then route the wire down the pillar then to front...
If lite is still in place it might be easier to use an old speedo internal cable and go from lite to switch or wire loom. Tape wire to end of cable and pull either up or down. Worked for me with turn signal wiring when I was with dealership. Good luck. Jim
