Steve is correct as usual. The only mirror they had was mounted on the A pillar post between the middle hinge and the top hinge on the drivers side.
Rusty Nelson
1928 Closed Cab's (starting about March) came with a mirror mounted at the sun visor (see first photo). This was also true of the early 1929 Closed Cab's (at least when mounted on the AA chassis).
The second picture shows an alternate mounting location found on some AA's and I don't know under what condition this occurred.
Thru February 1928 there was a hinge pillar mounted mirror setup for the Closed Cab (same location as in the second picture). The bracket mounting holes were closer together (see third picture). Only the AA was fit with a Closed Cab thru about August 1928 when it became available on the A.
