Need a little help here. Motor is 59ab, new Skip coil and distributor, new FA54 condenser. New plugs.
Motor is running very rough, especially at idle. Compression is between 85 and 90 pounds on all 8 cylinders. Getting ready to do a cylinder leak down test.
With the motor running, I pulled the plug wires off one at a time. This is where it gets interesting. Cylinders 1, 4, 6, and 7 are not firing. When I put my spark tester between those particular plug wires and the plugs, it has a big spark and I can hear the spark jumping as I lower the plug wire back on the plug. Interesting that is is every other cylinder in the firing order.
Thoughts?
Thoughts?
