Interesting French nameplate
deuce5wndw
I bought a 1935 roadster and in cleaning out the inside I found the pictured French nameplate. It has been attached but I don't find anywhere on this car that has holes that match. The car also has a very odd vin number on the frame! It has a normal 1935 vin but instead of having 18- it has 2226- in front of the number. Also instead of having the normal star it has like a waving flag for lack of a better term. Any ideas?
534584
534585
This IS some sort of a dealer tag, but you must remember that it was current roughly NINETY years ago. It is obviously The "Centrale FORD Agency" located in a huge building (indicated by the map I found on-line which seems to be subdivided into different entities). "52 - 56" appears on the map drawing as one of the divided areas, which could have easily been a garage of sorts. This is all located on a busy street called "Avenue du Prado" in Marseille, France. I found one picture of the entrance for what is now "54 Avenue du Prado ... remember that a lot has likely been modified in the architecture and structure during the past 80 - 90 years. It is likely still some sort of commercial entity today, possibly subdivided into office spaces as suggested by the speaker located on right wall of entrance.
Coop
Thanks Pete for the photo help and thank you Dick for the research! Hoping our friend from France will jump in here!
Clearly from a dealer as Ford of France was located in Asnieres-sur-Seine, a suburb of Paris, at that time, about 800 km away.
As DavidG stated, per the data plate.
Here are more Firewall tags. The one Robert posted is a '32 AN,19 hp,
The V8 is the '32.The AF is a '32 ,12 HP
Then there is a '33 and followed by a, '35 French .The last being a '35 from Belguim.
