That is a shame, a SouthBend lathe left to die. My first lathe was a big antique Lodge&Shipley, cheap, had been tipped over in a move, all the handles broke up, made to run off a line shaft, but 16"x6' so you could make wheels and drive shafts. I was told it was pre wwI due to no numbers on the dials, only hash marks. Lost it in the fire in 2010 I'll post a pic later.
I'm not sure about the power loss with a cheap converter, my lathe and bridgeport start rite up, and #3 is on a 20" disk sander. That machine is slow to get up to speed, but I've always thought its due to just getting that mass moving. Point is, GB's big grinder may act the same, but once up to speed they both will have a huge flywheel effect, and you can't really lean into it without burning the wood, or blueing the metal, so its irrelevant I believe.
Now, here's a typical thing GB will do with his new toy, due to his remote location, and in my case not patient enough to wait for a part in the mail or even wait for the store to open tomorrow morning. And lets not forget all his new"best friends" after folks on the island find out there is a machinist in town! (I charge a 6 pak minimum).
So, my 52 willys jeep had gobs of grease in a front brake assembly. Not just a seal problem, but the spindle had bad wear and rust pits. I got a good spindle from a friend, but it had the wrong bushing for the axle to spin on. The bushing sits in a recess so that there is no way to pull it out without wrecking it. No room for any kind of puller, and remove by screwing in a big tap would wreck it. They are made to be wrecked and replaced, not remove and reuse. So, I did this...
Checked for hardness with a hack saw...its soft. Then cut my old spindle off in the band saw about an 1/8" from the edge of the bushing. Then put the flange in the lathe and face it off down the the end of the recess, or the end of the bushing to see what size pusher to make on the lathe to press it out. In this case I had a hunk of shaft already made from some other project that fit good, so no new one was made. Keep in mind when you own a lathe you never throw away round things! So, I got the bushing out, its good, and better than new as the new ones do not have the grooves in the to help pump grease into the bushing. The same pusher will be used to press it into the spindle. Next, while the 4 jaw chuck was centered up for the flange I put the good spindle in the lathe and spun it while sanding up to 600 grit, she's smooth now!
Here's a crappy pic, never mind the mess, the maid hasn't showed up for work in a while.
