Reassemble in same position as when you dissassembled.
Follow #2, if it is past dissassembly now.
Good time to install the modified end plate if you don't have one already, and an o-ring at the sector facing the frame.
If the sector teeth are not too worn consider dressing the teeth. I had good luck following the instructions on Marco's web site.
Bob
