Intake manifold
Habusailor
I am looking for an intake manifold for a y block that is out of a Tee Bird or truck engine that has the baffle in the valley pan so I can put on a pcv valve
The easiest way out is to find in a salvage yard a 61-64 292CI F-SERIES with the PCV SETUP and take everything.
486758
What year FYB are you upgrading and 2V or 4V?
Finding a Y-block valley pan in an auto-salvage yard will be like searching for the proverbial "needle in a haystack." Unless you know of a yard that specializes in classic/antique cars, they don't hold onto cars for very long. What isn't stripped and sold, goes to the crusher. I see Y-block valley pans on Craigslist and ebay from time to time. Also check this forum's "For Sale" section, as well as on y-blocksforever.com. If you are not registered on y-blocksforever.com, go to eatonbalancing.com, send an email to Ted Eaton, and he will talk you through the y-blocksforever.com registration process.
Finding a take-off should be no problem as many of the cars-trucks were made with the setup(s). Especially in farming country.
Look at most any farm and you will see unused abandoned equipment.
If that fails - CASCO offers a conversion service for earlier pans.
Habusailor, on 2-22-22, a 1955-57 valley pan/cover was posted "For Sale" on the VTCI forum. The seller is asking $45. The ad is still up, but I don't know if the valley pan/cover is still available.
That's mine and I'm waiting for payment so it's probably sold
Here's one for a 2V setup (includes adapter) -
http://www.2040-parts.com/ford-292-motor-y-block-intake-manifold-valley-pan--i602869/
EDIT -
Actually, there is just one pan style (several versions released) for later ROAD DRAFT and/or PCV and PCV conversion). The pan style was introduced on the 1955 BIRD. FORD retained the closed style until the 1957 E-CODE and then 1958/ model runs.
The one shown above has the attaching parts for a 2V PCV SYSTEM.
And here - https://truckcapnew.com/ford_y_bloc..._312_292_thunderbird_car_truck_1955_1957.html
they started using these valley pans long before the pcv setup.a pipe for a down draft came out of them.i think they went back to 58 or close.i dont know how many of these i got from old trucks.as was said take a drive in the country.theres no shortage.
All bird valley covers can be used with modifications to the tube or a grommet. I do not know the PVC valve #for the grommet style. Any 61-64 car or pickup can be used with the stock hose connection. The correct PVC valve screwed into a fitting on the base of the carb on in a hose like above illustration for a truck shows. The # today that works is V100. The are stock for a lot of manufacturers.
It you use a grommet in any of them you must seal or put a screw into the threaded hole in the panel welded below or the valve you use there will suck oil into it.
There are manufacturers now making valley covers which accept the system and Blue Thunder is now making aluminum rocker covers that have the ability to have a breather or PCV system on top if you want to look like a SBC…
EDIT -
Only the pipe is a 2V part. The rest will work for a 4V. All you need then is the carb spacer, PCV and few pieces of short rubber hose.
That little teapot looking adapter is a very hard to find part.
