Could have also mentioned that most 1935 intakes have the same outward appearance as a 34 HOWEVER the hole under the fuel pump stand on a 34 is sort of "football-shaped" whereas the 1935 is "round" for the below-the-manifold baffle tube/flange to drop into, and there is a relief in the bottom of the fuel pump stand to clear the flange on the tube; the 1934 has the oil baffles in the FILLER TUBE, and the opening at the bottom matches the shape of the manifold where the stand mounts. The 1935 probably has a 48- part number....
KenCT PM'd me to let me know that what I posted before was not entirely correct.
I had posted that the 1935 manifold has a relief for the lip of the baffle tube, when in fact the relief is in the bottom of the fuel pump stand. Accordingly, 1934 fuel pump stands are different than 1935's in that respect. The oil filler tubes are also
different; the 1934 has baffles in the tube, whereas 1935's do not.
Ken: Thanks for reminding me that I am not 100% !!!
