intake manifold queston
harleynut
Question, my 30 Phaeton does not have a vacuum port on the manifold...or any place else that I can see. Is it supposed to?
Is this Jan-June '30 intake manifold the same as the 1928 manifolds that had no vacuum port, or are there some differences ?
There were at least 7 different manifolds used, four in 1928 alone.
One had the threaded hole with a domed plug, one had no hole, one had tapered "feet", and one with no hole but a bulge.
1929 the hole showed up again with an oval plug.
June - Aug 1929 had the boss but not drilled.
Mid 30 the hole was moved.
Details are in the Guidelines
