rg130
I have a question about the heat riser chamber under the carburetor portion of an Early V8 intake manifold. I believe the manifold is from the 38-42 period but not sure. While looking at the manifold off the engine I noticed what appeared to be a rod protruding from one of the heat riser holes. I attempted to pull it out with some pliers when it broke off. After some work I was able to get the rest of it out the hole in pieces and found what appears to be a fulcrum type device that was cast into the chamber when the manifold was made. I also noticed a metal pin in the bottom of the chamber which apparently held the device in place during casting. I have looked at other manifolds and never noticed a pin in the bottom and always thought the chambers to be empty. My question is what was its purpose and what years was it used if anyone knows.
