Greg Jones
I am looking for an "intake manifold extension" to lower a carb that has been adapted to run on a model T. This car belongs to a widow that asked me to help get it running better. Seems it backfires and pops going uphill. I drove it and found this is true, and I attribute it to fuel starvation. You will note in the photo that the gas line takes a couple of sharp turns and then quite a rise before entering the carb. This model T is a gravity feed system, and my conclusion is that the gravity system would work if the carb was lowered by 3-4" or so. Also, this Model T has the gas tank under the driver's seat. You might get enough head pressure if it was a 26-27 with the fuel tank higher in the cowl, I suppose.
So this takes me to my question. Anyone know where I might source pre-fabbed manifold extensions? I know I could get one fabricated but thought if someone is making such a thing already it is worth asking. I also know I could rig up a fuel pump but I don't care to do that.
