No sealant of any kind is necessary on the valve chamber cover (intake).Hi Barners, is it advisable to use a gasket sealant on a felpro intake? if so what kind do you reccomend ? (1937 block)
Thank you in advance.
Gary.
no sealer needed just will make it harder to get off next time.Hi Barners, is it advisable to use a gasket sealant on a felpro intake? if so what kind do you reccomend ? (1937 block)
Gary.
Give both sides of the gasket a smear of grease; it aids the sealing capabilities, and considerably eases removal further down the track. Brian
