Marco's instructions pretty much cover it for the top install, definitely trim the extra off, too much makes it hard to see where the tacks go. My biggest problem was I had 80 year old wood, with a couple sets of tack holes. I ended up using the long twisted trim screws to nail in the top material so I could reach something to grab. Ended up taking 3 evenings or about 8-9 hours after the old one was removed and everything cleaned up.
No chicken wire as there wasn't any under the old top.
I did mine when it was about 90 degrees in the evening, was plenty warm to stretch top.
If it matters I used the Snyders top kit, worked well, and there was plenty of extra material, probably close to 2' all around.
If your using old wood that has seen a couple tops put on, get a pack or two of the twisted trim nails.
Oh yes, it survived it's first 60 mile drive just fine
