chiefdave
There is so much info on installing aluminum heads that I am a little overloaded. So far I've gathered up the heads, permatex aviation sealer and Fel Pro non copper gaskets.
Most recommend using a spay sealer on both sides of the head gaskets. I've always installed head gaskets dry. What would be the advantage of using the sealer?
Torque recommendations are all over the place. Would 45 be OK in steps of 15/30/45?
With the increased compression would a step or two colder plugs be in order? A little extra timing advance?
This would be a good time to change thermostats. Given the advances in coolant over the last 70 years would 180's be suitable for year round use.
Finally could someone go over checking piston to head clearance? The block was decked during rebuild but the build sheet didn't specify how much metal was removed.
Thanks in advance for any help, Dave.
