bigd1101
Removing the old "Flame Thrower" coil and installing the new Flame Thrower, I ran into a mystery. The old coil was connected with the positive post running to a grounded nut on the radiator frame while the negative post ran to the distributor and then a wire running to the ignition out of the distributor.
Everything I've read says on the 6 volt system, you run the positive to the distributor and the negative to the ignition. Note that the distributor has an electronic ignition so maybe that is why the old configuration is set up this way?? I do know the wrong set up diminishes the power coming from these coils. Also, the plugs are gapped at .030 and it says I might have to re-gap the plugs a bit for the added spark power? I didn't notice any problems with the old gap with the old Flame Thrower coil....
Don
Don
