I'm installing modern valve keepers on my Model A engine. I'm using the Sunnen spring compressor tool. But the engine casting next to #2 doesn't allow the tool to fit under the spring. What's the trick for getting #2 installed? Thanks for all advice and tips. JimKrejci
You should try as many spring squeezers as you can borrow. There should be a lot of them in your local club.
Stick with it. It will go on. Some things, you just have to "worry" them off, and then back on. Take a break, and go at it again.
After trying several types of valve spring compressors, I settled on this one. It's not a perfect solution, but with a little effort, works accepably. As Tom suggested, a little grease on the keepers will keep them in place until they are seated.
I have used the same one "CarlG" recommends for decades. The only caveat is that you have to apply downward pressure on the anchoring feet, or they'll slip and the spreader disengages from the spring. #1 is always the hardest one for me because of the odd angle. But I always win.
Marshall
Keep your eyes open for a Sunnen valve spring tool. I have tried different spring compressors and find the Sunnen I show in the attached photo the best. I liked it so much I bought a spare. The Sunnen is much easier on your hands as it is long and has a lot of good mechanical advantage built in to the design. The sliding tab locks the tool in an infinite number of positions of spring compression. The width of the tip is adjustable to fit various components. I assembled about 40 engines last year and know from experience what type I like best. JMO
Good Day
The valve spring compressor on the left is the most efficient and it easily installs both #1 & #2 valves.
