Installing Mitchell Syncro ******
C4engr
Can I R & R a ****** without putting car on lift? I have the Mitchell ****** but no access to lift. I can put it on jack stands or whatever....
Any advise would be welcomed.
Roger
You can remove the transmission without a lift. You can pull the engine or you can put the car on jack stands and remove the rear end. either way is a lot of work but if there is a reason to remove the engine or rear end that will help you make the choice.
