31 Model A
Does a part of the center divider have to be cut out to accommodate the wire to keep it from being cut into when putting the light back into the taillight section?
These came from Snyders. The red wire that connect top board with bottom board cuts in the middle of the seperation.
Are there LED lights that look fairly stock when they are not on? I have seen some that really look out of place on a stock car.
Check your grounds...
Got them in, did not cut any wire, brake light left works great, break light right does not work. Thought maybe I had cut the jumper red wire, took it back off, no cut, put the old bulbs back in, brake light still doesn't work. Put LED back on, running light left side works, gets brighter when brake is applied. Right side...nothing, no running nor stop.
Sounds like its time to get out the volt meter or test light. Once you the right side is working, I think you'll probably want to cut the red jumper.
If you decide to hook up signals, that'll be fun. But, we'll get them working too.
I seem to remember if you install with the red wire not cut, all the LED's are on when the lights are turned on and become brighter when the brakes are applied.
When the red wire is cut, the upper and lower LED's are separated like the stock light, bottom side on with headlights, top side on with brakes.
If using option 1, uncut wire, you need to modify the separator for the wire to pass thru.
